Audi A7 Athletic, elegant and dramatic, the Audi A7 is a five-door coupe with the graceful look of a benchmark luxury sedan.
Oil change frequency
Old Feb 9, 2012 | 05:25 PM
halp's Avatar
Default Oil change frequency
I just had the 5000 mile oil change done and the service department pasted my next oil change to take place at 10000 miles. The service manual I have states that the mileage should be 15000 miles. What opinions do you people out there have?
halp
Old Feb 10, 2012 | 03:29 AM
jmarshall098's Avatar
The value stated in manual is an ideal value. Changing the oil depends largely on the driving habits and engine conditions. Replacing the oil a bit early will always be a better option to keep away from unnecessary problems. If you're a real care taker and drive your car smoothly without stressing much on the gas pedal, then oil changing at 15k miles will also work.
Old Feb 11, 2012 | 09:42 AM
halp's Avatar
Default oil change
Thanks for your input.
Since the oil is synthetic and has all the engine cleaners necessary, don't you think that 10K miles is OK for change intervals.
Could the dealer be looking for some 'profit' .
halp
Old Feb 11, 2012 | 11:23 AM
M5S5's Avatar
Tech Certified
I usually recommend every 5000 miles with approved 502 00 synthetic oil.
Old Aug 31, 2012 | 08:23 AM
Lawrencemichael's Avatar
Factory installed oils is not synthetic. Correct?
Old Sep 29, 2012 | 07:43 AM
I would go more than 5000 miles. The extra few bucks could extend the life of the motor or a much more expensive problem down the road.
Old Apr 24, 2017 | 03:52 PM
Pinspector's Avatar
2016 A6 2.0. We have Audi Care as it came with our CPO car. Recommended oil change interval is 5,000, then 15,000, then 25,000 etc or once a year. Does anyone else out there not have a warm and fuzzy feeling about changing the oil once a year? A6 takes 5 quarts with a filter and their "special" VW approved synthetic oil.
Old May 8, 2017 | 06:28 PM
Milane's Avatar
Agree with Lawrencemichael. I had my second oil change in the A6 3.0 TFSI, after a 10K interval. The oil was dark and dirty. From here on I will change it every 5K.
Old Mar 6, 2022 | 05:05 PM
kemo1985's Avatar
How do I know when my Audi A8 needs an oil change? How long can an Audi go without an oil change? How often does oil need to be changed in an Audi A8? What type of oil does Audi A8 take? Which Engine Oil For Audi A8? Recommended Engine Oil for the Audi A8. How Much Do You Need?
https://pmlauto.com/en/audi-a7-oil-c...pacity-recall/
frostytsm
B8 Models
Jun 19, 2013 10:17 PM
vivanov1
Feb 21, 2008 09:19 PM
vivanov1
Oct 11, 2007 11:04 PM
Diggitty
Mar 19, 2007 09:13 PM
TSRgeneral
Jan 21, 2007 02:09 AM
