2000 A8 Air Filter: How access air box screw?
Old Dec 16, 2012 | 10:44 AM
Carl & Kathy's Avatar
Default 2000 A8 Air Filter: How access air box screw?
I've had my 2000 A8 4.2L for about 8 months. I want to change the air filter. I can easily access 3 of the 4 screws on the air box. But the 4th screw is blocked by an air duct. Am I supposed to remove the air duct, and if so, how?
Old Jan 2, 2013 | 03:02 AM
nulif7's Avatar
Default do this:
l think if memory serves me best that there's
four screws to open the air filter box. you
will have to remove the air intake hose first.
hope this helps
Attached Thumbnails 2000 A8 Air Filter: How access air box screw?-remove-air-intake-tubing.jpg   2000 A8 Air Filter: How access air box screw?-intake-air-system-v2.jpg
Old Jan 2, 2013 | 09:32 AM
Yes, you are correct. I must remove the plastic air intake hose first. How do I remove the hose? Must I remove screws that hold the hose in place? Or is the hose the type that is just snapped together? If so, how do I disassemble the hose without breaking any of the plastic snaps?
Old Jan 7, 2013 | 06:44 PM
nulif7's Avatar
Default yah, there are two screws
that are 5/16ths or flathead screw driver to unlock
them. one on each end of the hose
Old Jan 8, 2013 | 06:56 PM
Nulif7: Thanks for your reply. Your attached thumbnail shows the wrong air duct. It shows the duct between the air filter housing and the throttle valve. This is not the air duct that blocks access to the air housing screw. The correct air duct is the one which is between the top of the radiator and the bottom of the air filter housing. Do you have a diagram that shows how to remove it?
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
911c4lover
Jul 2, 2012 09:22 PM
A_sixbiturbo
Mar 25, 2010 04:49 PM
ToddLower
May 14, 2009 08:44 PM
edmhess
May 10, 2008 11:02 PM
