2005 A8L VCDS Scan with Error Codes
I just scanned my a8l with VCDS, trying to work through some bugs and was hoping that someone on here could possible guide me a bit with some of these error codes and get this cleaned up.
below is the VCDS log I just took. THANK YOU IN ADVANCE!
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Ross-Tech: Home
Friday,15,July,2016,13:29:57:53355
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 72 77
VIN: WAUML44E55N016790 Mileage: 294210km-182813miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E3762803
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 285FE79E9B23707E16-807C
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Readiness: 0000 1100
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0054882
Coding: 0000002
VCID: 326B05F6ADFF0AAEB8-8066
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 22164 000 00000
VCID: 224BF5B6FD1F9A2E48-8076
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E3762803
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BF975EEBC300FE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 00000 785 00200
VCID: 2345F0B2E205932643-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346DN057521860
Coding: 0000003
Shop #: WSC 22164 444 58007
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 391DK057504460
Subsystem 3 - Serial number: 7411.04.0500000000291B0201˙
Subsystem 4 - Serial number: 1B0201˙
3 Faults Found:
02244 - Button in Control Head is Stuck
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 294171 km
Time Indication: 0
Date: 2016.07.14
Time: 19:06:52
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0001000
Bin. Bits: 000
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 14
Reset counter: 40
Time Indication: 15
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 176
Mileage: 294184 km
Time Indication: 0
Date: 2016.07.15
Time: 00:25:36
Freeze Frame:
Bin. Bits: 001
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000065139
Coding: 1052993
VCID: 1C37CB4EDF7BACDE82-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO30032005065A000000000120˙†89
Subsystem 5 - Serial number: 000120˙†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO24032005065A00000000
Subsystem 7 - Serial number: 65A000000000155˙
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E1 955 113 B
Component: ILM Fahrer H12 0210
Coding: 0143123
VCID: 31690AFAA8F931B6C1-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 22164
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 22164
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7119967
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D3021401
VCID: 2B5518928AD55B66FB-807E
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 2447F3AEE70B941E3A-8070
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C1AEAAACB1AD16ED-8030
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H54 0210
Revision: D06 Serial number: AUDID3E3004943
Coding: 0000203
Shop #: WSC 03855 444 12345
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0071
Revision: 00H06000 Serial number: 1200B127098021
Coding: E5D59F7F307A0E00
Shop #: WSC 22155 444 13987
VCID: 2D51168AB4C15556E5-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 176
Mileage: 289024 km
Time Indication: 0
Date: 2016.06.04
Time: 10:27:04
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 176
Mileage: 288802 km
Time Indication: 0
Date: 2016.06.03
Time: 10:29:53
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 291709 km
Time Indication: 0
Date: 2016.06.30
Time: 11:46:44
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378DS057520636
VCID: 387F37DE4B83E0FE86-806C
1 Fault Found:
02927 - DVD Read Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 52
Reset counter: 176
Mileage: 279778 km
Time Indication: 0
Date: 2016.03.21
Time: 13:50:16
Freeze Frame:
Hex Value: 0x5787
Hex Value: 0x722C
Hex Value: 0x04FF
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000506100058
Coding: 0003477
VCID: 1D31C64AC461A5D675-8048
4 Faults Found:
00213 - Control Circuit for Reading Lights Front Right
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 192
Mileage: 262136 km
Time Indication: 0
Date: 2015.10.02
Time: 19:24:00
00212 - Control Circuit for Reading Lights Front Left
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 232
Mileage: 262136 km
Time Indication: 0
Date: 2015.10.15
Time: 18:53:00
00215 - Control Circuit for Reading Lights Rear Right
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 67
Mileage: 262136 km
Time Indication: 0
Date: 2016.02.28
Time: 19:05:00
00214 - Control Circuit for Reading Lights Rear Left
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 262136 km
Time Indication: 0
Date: 2016.03.26
Time: 22:35:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0060
Coding: 0028204
VCID: 204FFFBEF313883E5E-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040504090059
Coding: 0065086
VCID: 275DE4A2963D7F061F-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
2 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 20
Reset counter: 137
Mileage: 292109 km
Time Indication: 0
Date: 2016.07.04
Time: 05:42:38
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 181
Reset counter: 137
Mileage: 0 km
Time Indication: 0
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000013762
Coding: 0000016
VCID: 2A5B1D96852F426E00-807E
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000059767
Coding: 0010111
VCID: 1E33C146C967BECE6C-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0N5TE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0060
Coding: 0028204
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
VCID: 1F4DFC42CE6DB7C667-804A
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 9
Reset counter: 176
Mileage: 290136 km
Time Indication: 0
Date: 2016.06.23
Time: 15:38:44
Freeze Frame:
Voltage: 13.04 V
Count: 236
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 62CBB5B6BD9FDA2E08-8036
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396DY057507844
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000005378
Shop #: WSC 22164 444 69314
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2804240736
Coding: 344530393135313035412056413032383034323430373336
Shop #: WSC 22172 444 57478
2 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 289514 km
Time Indication: 0
Date: 2016.06.09
Time: 17:24:59
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 147
Mileage: 292028 km
Time Indication: 0
Date: 2016.07.01
Time: 23:53:45
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0028204
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900031333
Coding: 0232125
VCID: 5FCDBC428EEDF7C627-800A
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000503290295
Shop #: WSC 12336 024 394758
VCID: 346703EE57EB049EAA-8060
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0028204
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007520804
Coding: 0010900
End-------------------------(Elapsed Time: 03:14)--------------------------
Ross-Tech: Home
Coding: 0007773
1 Fault Found:
Coding: 0000002
Coding: 0007597
1 Fault Found:
Coding: 0410624
Component: ELV XXXX
Coding: 3940576
Coding: 0000003
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 294171 km
Time Indication: 0
Date: 2016.07.14
Time: 19:06:52
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0001000
Bin. Bits: 000
Freeze Frame:
Fault Priority: 5
Fault Frequency: 14
Reset counter: 40
Time Indication: 15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 176
Mileage: 294184 km
Time Indication: 0
Date: 2016.07.15
Time: 00:25:36
Freeze Frame:
Bin. Bits: 001
Coding: 1052993
Coding: 0143123
Coding: 00000035
Shop #: WSC 22164
Coding: 00139548
Shop #: WSC 22164
Coding: 0530707
Coding: 0012141
Coding: 0000203
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 176
Mileage: 289024 km
Time Indication: 0
Date: 2016.06.04
Time: 10:27:04
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 176
Mileage: 288802 km
Time Indication: 0
Date: 2016.06.03
Time: 10:29:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 291709 km
Time Indication: 0
Date: 2016.06.30
Time: 11:46:44
Coding: 4071658
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 52
Reset counter: 176
Mileage: 279778 km
Time Indication: 0
Date: 2016.03.21
Time: 13:50:16
Freeze Frame:
Hex Value: 0x5787
Hex Value: 0x722C
Hex Value: 0x04FF
Hex Value: 0x0000
Coding: 0003477
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 192
Mileage: 262136 km
Time Indication: 0
Date: 2015.10.02
Time: 19:24:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 232
Mileage: 262136 km
Time Indication: 0
Date: 2015.10.15
Time: 18:53:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 67
Mileage: 262136 km
Time Indication: 0
Date: 2016.02.28
Time: 19:05:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 144
Mileage: 262136 km
Time Indication: 0
Date: 2016.03.26
Time: 22:35:00
Coding: 0028204
Coding: 0065086
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 137
Mileage: 292109 km
Time Indication: 0
Date: 2016.07.04
Time: 05:42:38
Freeze Frame:
Fault Priority: 3
Reset counter: 137
Mileage: 0 km
Time Indication: 0
Coding: 0000016
Coding: 0010111
Coding: 0028204
Revision: A32C0220
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 176
Mileage: 290136 km
Time Indication: 0
Date: 2016.06.23
Time: 15:38:44
Freeze Frame:
Voltage: 13.04 V
Count: 236
Coding: 0000001
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 289514 km
Time Indication: 0
Date: 2016.06.09
Time: 17:24:59
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 147
Mileage: 292028 km
Time Indication: 0
Date: 2016.07.01
Time: 23:53:45
Coding: 0028204
Coding: 0232125
Coding: 0028204
Coding: 0010900
