A8 transmission interchange
I am switching to a manual.. If that helps any? I mean I do have auto pulled anything info you need? I maybe able to take pics to help...
Yes and no ....the pedal assembly does have a space for clutch pedal. And most parts bolt up to replace whatever part you're replacing. there is no part for drive shaft and clutch flywheel's trigger teeth must be adjusted for relocation of CP's in the 01e trans. Add far a I'm aware the ecu won't automatically adjust for that many degrees of offset.
