A8 in trouble
Old Dec 13, 2009 | 05:26 PM
dannyghost's Avatar
Member
Default A8 in trouble
ok guys and girls,
I ran a VAG test few days ago.
Now, for reminder, I didnt drive my car since March this year as it was unregistrared, just few short drives down the street after engine was on working temp every few days in a week.
I had to replace old batery in June after it died on me.
So, my car was under stress because he lost all electric power.
I am hoping that all those problems on VAG test are results of that.
Here is test result:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4D0 907 557 K
Component and/or Version: 4,2L V8/4V MOTR AT D02
Software Coding: 04273
Work Shop Code: WSC 00000
11 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-00 - -
17605 - Oxygen (Lambda) Sensor Heater Circuit: B2 S1: Electrical Malfunction
P1197 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
Control Module Part Number: 8E0 614 111 M
Component and/or Version: ABS/EDS 5.3 QUATTRO D41
Software Coding: 0273004134
Work Shop Code: BB 24302
1 Fault Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
30-00 - Open or Short to B+
Control Module Part Number: 4D0 919 033 M
Component and/or Version: D2-KOMBIINSTRUMENT D33
Software Coding: 00083
Work Shop Code: WSC 00425
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
00667 - Ambient Temperature Signal
here is next one after we made restart of the system:
5 Faults Found:
P0102 - 35-00 - -
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
P0154 - 35-10 - - - Intermittent
P1196 - 35-00 - -
P1197 - 35-00 - -
8 Faults Found:
P1196 - 35-00 - -
P1197 - 35-00 - -
P0102 - 35-00 - -
P0300 - 35-00 - -
P0301 - 35-00 - -
P0304 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
I am hoping that u will give me some ashuring advice...
thx
Old Dec 13, 2009 | 09:48 PM
milivojsa's Avatar
Default missfire
Had similar problem as yours,misfires,replaced spark plugs,coil packs,oxygen sensor and nothing,after removing air flow sensor car running no problem .Good luck.
Old Dec 13, 2009 | 10:05 PM
auditech79's Avatar
Agreed, disconnect the MAF sensor and see if it improves, if it does, you have a faulty MAF sensor.
Old Dec 14, 2009 | 11:34 AM
dannyghost's Avatar
Member
thanks guys.
what about lambda sonds? can they be solved with faulty MAF?
Old Dec 15, 2009 | 12:32 AM
auditech79's Avatar
Can a bad MAF cause O2 sensor codes? Yup.
Old Dec 15, 2009 | 02:53 AM
dannyghost's Avatar
Member
thanks,
I am going out to dig my silver hog out of the snow..and start to remove those sensors.
btw. where can this MAF be?
Old Dec 15, 2009 | 11:05 AM
auditech79's Avatar
Its the main sensor just after the airbox in the intake. It should have a large sensor connector, you can't miss it. What i would do is start the car, and while its running disconnect the sensor, if it magically starts running smoother you have a bad MAF.
Old Dec 15, 2009 | 01:08 PM
dannyghost's Avatar
Member
ok, cool.
Old Dec 23, 2009 | 07:36 AM
dannyghost's Avatar
Member
i tried to find MAF sensor, nothing on the tube, but found soemthing inside of filter box
[IMG][/IMG]
[IMG][/IMG]
is that it?
i left cable unhooked and start engine, but besides vibrations, no CAT light when up..
can i assume without vagcom that i found the problem?
Old Dec 23, 2009 | 10:59 AM
auditech79's Avatar
Oh yeah thats the MAF, i forgot its like a 1.8T engine with it inside the air box, sorry about that. So it ran much better with it disconnected?
