Air conditioning blows warm air and Door chime
Old Nov 13, 2010 | 10:49 PM
schiu's Avatar
YES . I've asked the dealer to drain all the old freon , clean the system by flushing the condenser coil and regas with new freon. The car is now nice and cool , my advise is to try something simple like this rather than going to the expensive solutions like water valves etc . The freon tends to lose 20% of its capability due to moisture contamination each year
Old Nov 14, 2010 | 07:32 PM
CarlosMIA's Avatar
The same was recently done but did not help.
Old Nov 19, 2010 | 12:31 PM
johnlav's Avatar
There is separate fuse for the side dash air vents. If it's blown, everything works except the side and middle vents. They will blow warm air.Check your owners manual and examine the fuse situation.
Old Nov 19, 2010 | 07:05 PM
silverd2's Avatar
If the fuse is OK:
Just a shot in the dark (haven't experienced the problem myself), but all sealed refrigerant systems are basically the same and easy to rule out when that portion of the climate control system is "sound".
Even without a DTC code, I'd be searching for an electronic, electrical or mechanical "control" problem...starting with mechanical: the temperature control flap motor and flap behind the dash/console...not too hard to access, if you want to eliminate it as a problem. A visual inspection might be worth a try...even with a perfectly functioning "sealed circuit", the cold could be prevented from getting routed to the right place due to a flap motor or flap malfunction.
Granted, this (and other controls)should throw a code, but not impossible...sensor circuits can fail...and if your system is NOT working, with no codes, something failed.
Plus if you didn't personally run the diagnostic, there's always a possibility that an idiot DID
wildwoodTT
May 5, 2014 12:33 PM
domenicostorino
Nov 1, 2010 12:39 PM
225tt
Mar 3, 2007 08:04 PM
tim7902
Sep 10, 2006 01:30 PM
markgcb1
Jul 22, 2006 12:22 AM
