Brake rotors for A8
In a few posts in this forum it was mentioned that the brake rotos should also be replaced at times, when renewing the brakepads.
My A8 has about 86K mileage on it and off and on while applying on the brakes at speeds 50 miles and higher, the from of the car starts waving and slightly shaking. I was wondering if changing the brake rotors would help or is that just worn out brkae pads. Any ideas?
Thank you,
Thank you,
Thank you for your input.
Well, I took a look at the service history of the car, it seems that the front rotors were replaced at 50K miles. I think the rear ones are still the original thoug. Do you think I should replace all 4 rotors now?
In terms of the ceramic pads, are they noisy? DO they last less than the regular ones?
Thank you again,
A.
Thank you again,
A.
Haven't had to do brakes on mine yet, but there is much discussion on how often rotors should be replace on these cars.
General consensus seems to be every second set of brake pads.
And in general, with everything working properly, rear pads/and rotors last almost twice as long as fronts...front do almost all the work, and engineering goes a long way to see to that...even without ABS working...for safety.
adamsrotors
Jun 25, 2015 02:32 PM
adamsrotors
Jun 25, 2015 02:31 PM
adamsrotors
Jun 25, 2015 02:20 PM
adamsrotors
B8 Models
15
Jun 25, 2015 02:08 PM
adamsrotors
Jun 25, 2015 02:03 PM
