help needed - unbolting gearbox
Old Nov 9, 2010 | 12:29 AM
340i's Avatar
Default help needed - unbolting gearbox
Hi,
Hopefully someone can help me with a problem I have...
I have removed the v8 and quattro box from my 96 A8 and unbolted all the bellhousing bolts but the gearbox wont come off. Is there some trick to it or is it just stuck and needs a good handfull of leverage applied to it?
Tips much appreciated
Old Nov 9, 2010 | 08:42 AM
silverd2's Avatar
Have you removed the starter & unbolted the TC from the drive plate?
Old Nov 10, 2010 | 01:23 AM
340i's Avatar
no i havent done that, ill give it a go. i hear i might need to unbolt the torque converter but i didnt know how to access it. thanks
Old Nov 10, 2010 | 08:48 AM
silverd2's Avatar
Should be 3 bolts...turn engine 1/3 rev at crank pulley (T-belt installed!) to access each through starter 'hole'.
Old Nov 11, 2010 | 09:50 PM
aspen79's Avatar
Even with ALL the fasteners off, they sometimes are still stuck from corrosion to the alignment pins (steel pins into aluminum housing).
cjfoley1985
May 6, 2015 07:41 PM
Theradlettfineart
Oct 15, 2013 05:35 PM
thenjd
Jan 23, 2008 04:00 AM
antoncole
Oct 3, 2006 05:11 PM
