Hid bulbs replacement
Wondering if any of you have replaced your Hid bulbs on your A8?? I noticed on the weekend that the passenger side one has gone pink and not white like the drivers side and when I have done a Google search everone has said that when your light goes that way it is about done.
Is it relatively easy to change on a 2007 A8 and would you buy them from the dealer or some other brand??
I have done mine, its a 2004 A8. Although the D3 models are the same. Here is a link to help you with your question.
https://www.audiforums.com/forum/aud...dlight-168967/
Dealer cost is very high. One of our members (Emilgevor) owns Krauto Parts - he can sell you replacement bulbs at a much lower cost. Many of us in the A4 and S4 forums have and endorse his products. Also, he can get you 4300k bulbs (same color temp as OEM) or other color temps if you want. He's got other products as well, like LED interior, license plate, and reverse lights. I have practically his whole catalog in my car and love it. Definitely worth a look - he's a standup seller.
Thank you very much for the shout our Mr Devil
OP I replied to your email regarding these earlier today. Basically what you heard about PINK headlights is true. Sounds like your lights is on its way out. When I bought my 2000 S4 the lights were very washed out and felt like they were much dimmer then most of the cars on the road even with my projector housing.
I ended up replacing bulbs and noticed huge difference in output even tho It was plugged in to the same OEM ballast. Later on I ended up converting whole thing to 55w setup and new headlight housings (E-codes) and now I couldnt be happier with the setup.
The bulbs that you asked me about earlier are D2S for Low Beam and H7 for High Beam.
Simple replacement and no need to spend over $100 for a set.
Hope that helps
Hope that helps
Hope that helps
Hope that helps
JK man
Yeah I received an email from what I thought was you and replied right away.
