How-to: 2004 A8 Oil Change Procedure
Old Jan 2, 2012 | 02:59 PM
  #21
conekiller13's Avatar
Is there a way to reset the oil life monitor?
Old Jan 15, 2012 | 05:53 PM
  #22
Mdeeze's Avatar
You need a vag com in order to reset it.
Old Sep 10, 2012 | 02:32 PM
  #23
dollah1's Avatar
thanks folks for posting this. every mechanic ive been to outside of a dealership has been stumped and I have a few mechanics for friends.
Old Sep 27, 2012 | 10:42 AM
  #24
Aatos's Avatar
Default Oil Drain plug location??
Can anyone tell me where the oil drain plug is? I've taken off the plastic cover and the drain plug that I am guessing at is totally inaccessible without removing a massive metal sub structure. Am I out to lunch?
Thanks
Old Sep 27, 2012 | 01:49 PM
  #25
Aatos's Avatar
I found it! Duh! I'm used to other makes, with small hex head bolts. This was too obvious, and strange looking!
Old Jan 2, 2013 | 08:20 PM
  #26
Radar21's Avatar
Default Washer in new filter cartridge box
Help!! Changing oil now and can't figure out where washer/crush ring? that comes with the new cartridge goes.
Old Jan 7, 2013 | 08:48 AM
  #27
Lobstah's Avatar
How different is this for the 2008 model?
Old Jan 8, 2013 | 08:33 AM
  #28
Aatos's Avatar
I changed the oil on my 2004 a few months ago and was given a second crush ring to use, in addition to the one in the package. Neither ring fit anything. I just used the old one again, with no apparent problems.
Old Jan 9, 2013 | 07:54 AM
  #29
Radar21's Avatar
Default Crush ring
I did not use it either. At first, since it came with the cartridge filter, I thought it should be for use inside the block with the cartridge, but could not find anywhere it would go. Definitelly did not fit the drain plug in the oil pan. So, I just used the old one for that. My only thought is that it may be for the drain where the filter cartridge goes, but I couldn't find that.
Old Jan 10, 2013 | 10:37 AM
  #30
Aatos's Avatar
Didn't fit that either. My drain on the oil filter housing was stripped and I had to install a threaded insert that allowed me to use the old plug, but neither crush washer fit that. I misplaced the old one so ended up with a copper one - probably not ideal, but all I could find in the area.
