No sound from speakers. Please help!
Old Oct 18, 2014 | 05:41 PM
Shalviin's Avatar
Default No sound from speakers. Please help!
Hi guys. My nav, radio and cd player appear to be running fine on the MMI. But there is no sound from any of the speakers. I have taken the amp out but there is no visible damage to it. Is there a way to test it to see if the amp is the issue? I would hate to buy the amp and find out that wasnt the problem. Also, there is no sound when I press the voice command button either. But the parking sensor beeps work fine. Appreciate the help! It is a 2004 A8L with Bose system.
Old Oct 19, 2014 | 10:49 AM
jakematic's Avatar
Parktronic has a separate set of beepers.
What does an Auto-Scan say ?
It is possible there is a break in the MOST ring somewhere too, but a scan is the best place to start.
Old Oct 26, 2014 | 12:32 PM
Shalviin's Avatar
Thanks Jake. I got a used amp and swapped it out but no change. I will return the amp. I have a scan scheduled for next saturday so lets see what that says. It will cost me 95 bucks just for the scan. I will keep you updated.
Old Oct 26, 2014 | 02:43 PM
jakematic's Avatar
Holy cow
Three of those would pay for VCDS....
Old Dec 19, 2014 | 10:09 PM
Shalviin's Avatar
Ok guys. I really need your help here. These are the audio/entertainment related fault codes I found through a VCDS scan. Can anyone tell me what these mean or what module or problem these point to? Appreciate the help!!!
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346HH037505400
Coding: 0000103
Shop #: WSC 26147 444 00899
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301H9037524040
Subsystem 3 - Serial number: 7422.08.030000000000010000ÿ
Subsystem 4 - Serial number: 010000ÿ
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 9
Reset counter: 39
Time Indication: 1
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 020050370804DE
Coding: FCFE7FDD1B2304
Shop #: WSC 26147 444 58994
VCID: 264310139112D62ECEF-8073
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 64
Reset counter: 35
Mileage: 233017 km
Time Indication: 0
Date: 2014.12.04
Time: 09:10:13
Address 47: Sound System
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304HC037540141
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 204F060BF336381EB43-8075
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 131
Reset counter: 22
Mileage: 218462 km
Time Indication: 0
Date: 2014.05.31
Time: 17:46:14
Old Jan 30, 2015 | 09:58 PM
1BigPea's Avatar
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 39
Time Indication: 1
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 64
Reset counter: 35
Mileage: 233017 km
Time Indication: 0
Date: 2014.12.04
Time: 09:10:13
Cannot be reached
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 22
Mileage: 218462 km
Time Indication: 0
Date: 2014.05.31
Time: 17:46:14
Did you ever find a solution to this problem? See my post at the link below. I need help.
https://www.audiforums.com/forum/aud...hanger-167579/
Old Jan 31, 2015 | 10:38 AM
Shalviin's Avatar
BigPea. The first thing you need to do is get a vagcom scanner. I got a imitation one from eBay for 30 bucks and it worked fine. That will scan each module and let you know if there are any issues. Also, get a fiber optic loop. Then unplug one device in the series at a time and use the loop to complete the circuit. That will allow you to find the culprit module. Be sure to do the module and BUS scan using vagcom and post the results here. We can then try to help. I fixed mine this way. It was a bad amp and I had to get an amp with the exact same sw and part number. Good luck buddy
Old Feb 1, 2015 | 04:44 PM
1BigPea's Avatar
Hey man, thanks for the response. I talked to a buddy who works at an Audi dealership here in SoCal. He said to bring it in tomorrow and he'll see if he can get someone to hook it up and get me the results.
I'll post here when I have them and keep ya updated. :cheers:
synesthesia
Feb 16, 2015 11:35 AM
tipset6069
Apr 15, 2009 04:44 PM
theperfecto1
Mar 7, 2008 03:00 PM
theperfecto1
Mar 7, 2008 11:04 AM
TeeterTawter
Jul 23, 2007 02:09 PM
