question about specific cluster lights
I have two lights in my cluster that I don't know what they do or light up under what circumstances.
1- ''CAT'' does it light up when the cat converters are too hot ?
2- immobilizer/security... no idea when it should light up
thanks
thanks
CAT= Catalyst Warning System, Used for P04XX codes dealing with the catalytic converters or O2 sensors.
Security/IMMO is for the immobilizer. If you try and start the car with a key that is not registered with the IMMO box, ecu, or cluster the car will shut down after 2 sec and the light will flash. This light should come on for about 1 sec and turn off after a registered key is inserted into the IGN and turned to the on position.
L_U_D_I_AAudi
Jun 3, 2012 04:09 PM
MartinCieslak1
Mar 20, 2010 08:47 PM
