Replacing Fuel Pump ?'s
I'm LS1Guy and can't remember my password... The videos were great and I was able to put everything back in. Is there ANY way to ensure the assembly is properly seated without buying the fancy scoping tool? I tried to start it up and its throwing the [manual says] "Malfunction Indicator Light" code. I'm assuming that means I didn't seat it correctly but since I won't be able to give it another try until tomorrow, i figured I'd ask before dropping god knows how much on that scope.
Thanks for any help
Thanks for any help
I took the assembly back out and seated it correctly using a snake cam, so it IS properly seated now but it still stalls out when trying to start it... anyone have any ideas?
P.S. For any other bargain hunters, this "tool" will work just as well as the bentley I keep seeing mentioned, if you plug it into your laptop and use it as a webcam.
http://www.walmart.com/ip/Spy-Net-Sn...i_sku=14699225
or where i can find the gasket set at the very beginning of this video?
http://www.youtube.com/watch?v=no5K_Ri6xBA
Of the few places that have it ( 4D0 298 133 c ), this place has it the cheapest I've seen...and I've dealt with them successfully:
http://www.genuinevwaudiparts.com/pa...?siteid=214407
Sorry, if you wrote it, I missed it...what year model car? 2000 on have an immobilizer circuit...not likely the problem unless you've had a remote key problem too.
Back to a couple of basics. If crank but no start: fuel and spark?
Is the fuel pump actually running during start attempt...relay energized...all fuses OK? Hook a meter to the pump leads during start.
If pump is running, may have to check to see that fuel pressure is making it to the rails at engine. If so are injectors getting signals? If so, are coils getting signal from ECU.
it looks like there is something that stops the fuel from reaching the rail after a certain point.
Hi group!
Can anyone give me the part number for the replacement pump?
1998 A8 Quattro (American)
I pulled the assembly out. Looking at the pump and there is nothing on it!
