replacing the master brake cylinder
Old Jan 8, 2014 | 02:58 PM
avdwaal1's Avatar
Default replacing the master brake cylinder
hi,
I am replacing the master brake cylinder and I have an issue removing the nut that holds it to the booster. The first (20mm?) nut (from the drivers side) is fairly accessible with a wrench, but the other nut (seems like 22mm) is hard to reach, there not a lot of room to work.
Do I need to remove other parts to get access? What tool(s) did you use? I figured if I can get the brake reservoir off it would be easier but I can't figure out how to get it off as again there is no room to work. There is this metal bracket that is in the way.
HELP!
Arthur
Old Jan 8, 2014 | 03:17 PM
avdwaal1's Avatar
Think I figured it out. One has to remove the tower brace in order to remove the reservoir, then the master brake cylinder can be removed.
Misssofia
Oct 6, 2010 05:32 AM
Theiceman
Jun 20, 2010 01:19 AM
AudiAggie
Jul 25, 2009 05:17 PM
Dallas09
Apr 7, 2009 03:16 AM
justin8
Apr 4, 2009 05:57 PM
