Threw a couple codes...Need some help!!!
Old Apr 26, 2008 | 04:53 PM
kworker17's Avatar
Default Threw a couple codes...Need some help!!!
I went to autozone and got a free reading. They came back with...
[ul][*]Code P0442 - The PCM has determined that a small leak exists in the evap. emmisions control.[*]Code P0422, P0432- The PCM has determined that the main catalyst efficency for bank 2 is below threshold for the current engine opperating conditions. (Bank 1identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank).[/ul]
I was told that code P0442 was possibly just the gas cap and it needed to be replaced. Could the other codes be a ICM? From what i've read on the forum, it seems to happen alot to our cars. Thanks for your help!
Old Apr 26, 2008 | 06:11 PM
tru_pimp's Avatar
Default RE: Threw a couple codes...Need some help!!!
I work for gm and usually when we get low efficiency codes its cause the catalytic converter is bad. as far as the small evap leak, yah the majority of the ones we get here are gas cpas either left loose after fill up or it being bad and actually leaking vapors. but dont overlook the other evaporative emissions related parts. have also found vent solenoids staying stuck open. could also be an open in a hose or line. good luck!
Old Apr 26, 2008 | 08:42 PM
kworker17's Avatar
Whats the best way to find out. I know the converters can be expensive, so I'd rather not replace it unless I have too. Should I bring it to Audi? Thanks!
daghstdrummer
Jun 1, 2009 11:30 AM
hiwords
Nov 24, 2007 12:06 AM
less_of_me
Jun 10, 2007 11:08 PM
Trey25
Nov 27, 2006 12:16 AM
JDCrowe
Apr 18, 2006 09:30 PM
