Tire sizes for d3
Old Mar 18, 2011 | 10:13 PM
tunecinator's Avatar
Default Tire sizes for d3
Has anyone ever put a 275 35 19 on an a8l d3 .Looking at replacing my summer tires with a little more width. Thinking of putting them on a 19x 9.5 et 35 rim.
Old Mar 18, 2011 | 11:04 PM
silverd2's Avatar
You've probably already done the calculations, but from 255/40/19 on et 45mm stock (optional) D3 19x8.5 rims - to - 275/35/19on et 35mm 19x9.5 will protrude a full 20mm more, which should look "mean" as long as it clears the fender lips...should easily clear on the inside, though.
Also just a hair shorter than "stock" ...26.6" instead of 27".
Old Mar 19, 2011 | 12:42 AM
FlyTyinFool's Avatar
silverD2 Is spot-on. About 3/4 inch out toward the fender, but hardly any difference inside. That's going to be right at the fender. And, the difference at the speedo will be only 1 mph less (actual 59) when it reads 60.
Since there is still plenty of room to give on the inside, you could always increase the offset a wee bit, if they sit too far out. It wouldn't need much though, if any.
That should make a really nice, wide, aggressive, mean looking stance.
Pics when you've got the new sneakers on her!
Old Mar 19, 2011 | 10:10 AM
Yes I have done the calculations,also some newer models came with 20 inch wheels and 275 35 20 's. I am sure the 19 inch tires will work ,I have also seen post of spacers of 20mm on the rear and 10mm front, it's the missing 10 mm in the front I am worried about. Fender lip rub or turn in issues. Thought I would retire the old fan wheels to winter rims and give the car a different look after 5 years
GoremanX
Sep 10, 2012 01:16 PM
ballswell
Aug 15, 2008 10:08 AM
CamoA6
Jun 10, 2008 02:41 PM
chitownA4
Aug 20, 2006 05:23 PM
insuite
Sep 22, 2005 08:05 PM
