Transmission service...
Old Jan 15, 2009 | 06:22 AM
vwbuge's Avatar
Member
Default Transmission service...
I was looking into another A8L. The owner tells me that the transmission is a sealed unit. I find that hard to believe.
I was looking for a car with service history. Control arms, transmission fluid changed and timing belt/water pump replaced. Anything I am missing?
Old Jan 15, 2009 | 11:55 PM
auditech79's Avatar
The transmission is serviced from the bottom, and its completely sealed unless you take out the fill and drain bolts on the pan. This must be done with a special tool.
Old Jan 16, 2009 | 09:50 AM
vwbuge's Avatar
Member
So, is it a straight forward procedure if you have the right tool? You can't fill it from the top?
Old Jan 17, 2009 | 11:43 AM
auditech79's Avatar
No, the tool is a gravity feed instrument. Basically there is a tank that you suspend from the hood latch and a hose runs all the way under the car and up through the fill port. You also cannot fill the transmission without the VAG COM, the reason for this is you need to monitor the transmission temperature. If the temp is too hot or too cold you won't get the correct fluid level. Basically it has to be 32*C when you dump most of the fluid in there, before starting the car you put in around 3 liters to prime it, once the fluid starts leaking out of the fill port around that temp then the trans is full.
Old Jan 17, 2009 | 02:53 PM
vwbuge's Avatar
Member
It sounds like a hassle for the DIY guy. What is the recommended interval for the flush and do you know the cost at the dealer for this service?
Thanks,
Paul
Old Jan 18, 2009 | 01:15 PM
auditech79's Avatar
I would do it every 60-80k, no longer than that. Another reason i say that is when servicing the transmission the tech might notice a leak on the pan, torque converter seal etc. which can prevent major problems down the road.
Old Jan 19, 2009 | 12:32 PM
audiday's Avatar
controll arms does not matter - it does not cost so much as transmission and engine. transmission and engine first things to check
ccmnova
B7 Models
Feb 19, 2014 10:40 AM
calmone
Jan 16, 2011 04:08 PM
lboudreau
Sep 10, 2007 09:21 AM
bihoang
Jul 31, 2006 09:43 PM
MeanAudiA6
Jul 15, 2006 07:37 PM
