Hey Guys,
I was wondering if you could help me out with a problem with the top operation on my TT.
Backstory:
I picked up a 01 225Q Roadster from my friends mother a few years ago that was a bit of a mess as the CCM was out and needed a bit of maintenance. Low miles at 50K, but had sat for long periods of time. It needed a CCM, rear window glass repairs, tires, brakes, battery, airbag light on, rear window shade belt, etc... I drove it for a year and then it's been driven infrequently since. I'm ready to sell it as I no longer drive it.
Problem:
I've since replaced the CCM and everything associated with it is working as expected (one touch windows, map lights, door sensors, central locking, etc...) except the convertible top. I get nothing at all. Also, I never receive a top open light when I had the top open manually or now. I know a lot of people have issues with it stating it is open when actually closed, but mine's the opposite.
What should I check?
Does the CCM need to be coded to a roadster with a top? It seems there is an option to tell the CCM about it via this chart. http://audittrs.files.wordpress.com/...ing-values.jpg
When the top is down and the windscreen up, if I manually pull the top up the windscreen retracts.
Does the top sensor above the windshield have anything to do with this? Currently when I open the door the drivers window retracts but not the passengers side.
When I open the top manually neither window retracts.
My thinking is that if the car doesn't know the top is unlatched the top wont function. Whether or not that is because of the top sensor switch or the CCM not coded correctly is a question I have. Although, the previous owner swears that there was never a light on the dash for the top being open when he drove it, but the top still worked prior to the CCM failing, though he did have window up/down problems.
I need to have my friend with his vagcom come out and code the remotes for the keyless entry but would like to know if something else may be wrong.
Any ideas?
Backstory:
Problem:
Any ideas?
I'm having the same problem, absolutely no response when I unlatch the roof or open it manually. I have tried pressing and depressing the switches with a screw driver with no response. I have also had a look at the switches with the covers off, but can't see anything weird looking. I'm thinking about taking the microbswitches off to see if I get a response. Any help would be apreciated.
greetings Ross.
greetings Ross.
Backstory:
Problem:
Any ideas?
Originally Posted by -p-
Hey Guys,I was wondering if you could help me out with a problem with the top operation on my TT.
Backstory:
Problem:
Any ideas?
