02 sensor / fuel filter / upgraded plugs! I need your help!
Old Jun 8, 2007 | 12:40 AM
bmwtoaudi's Avatar
Default 02 sensor / fuel filter / upgraded plugs! I need your help!
I need to replace my O2 censor in bank 1.
Where is it located? - What is the best way to remove and insert the new one?
Fuel filter - Where is it?
Where is it located and what is the best way to remove the old and insert the new?
Plugs, Its pretty self explaing. - Does this car have anything special I should be watchful of?
I'm also adding a KandN air filter into my current box. - Anything I should watch out for?
Thanks guys!!!!!!!!
Old Jun 8, 2007 | 12:56 AM
cincyTT's Avatar
I'm make believe
Default RE: 02 sensor / fuel filter / upgraded plugs! I need your help!
ORIGINAL: bmwtoaudi
Where is it located? - What is the best way to remove and insert the new one? - in the dp about 1' below the turbo. you should be able to remove it with the dp still attached. make sure you use plenty of pb blaster/wd40 and a o2 socket to get it out.
Spark Plugs
[ul]OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
[*]NGK BKR6E
[*]Autolite 3923
[*]Denso Iridium IK20
For Chiped Cars - .028" gap:
[*]NGK BKR7E
[*]Autolite 3922
[*]Denso Iridium IK22
[/ul]
I'm also adding a KandN air filter into my current box. - Anything I should watch out for? - should be nothing but when you clean it, dont over oil it.
Thanks guys!!!!!!!!
Old Jun 8, 2007 | 10:20 AM
bmwtoaudi's Avatar
Does anyone know where the fuel filter is located? - Or know a website I can look on to find a general location?
Thanks!
Old Jun 8, 2007 | 10:23 AM
techbod's Avatar
full details are required of your car age/engine cc/awd/fwd
Old Jun 8, 2007 | 10:26 AM
techbod's Avatar
im not going to look it up because you have a sig and it should be in there
Old Jun 8, 2007 | 11:06 AM
bmwtoaudi's Avatar
2000 FWD - 1.8T
Old Jun 8, 2007 | 05:07 PM
bmwtoaudi's Avatar
Bumptity bump bump.
Old Jun 8, 2007 | 05:22 PM
MeanAudiA6's Avatar
fuel filter is an easy DIY....its located on the rear passanger side near the fuel tank....you will have to remove the plastic protector cover to gain access.....then you will easily see it there. just follow the fuel lines...also to undo the connectors you have to push the tabs in and pull out. called "push tabs"
skihigh2299
Oct 11, 2015 05:54 PM
drb321
Apr 30, 2010 11:02 PM
MC Hammered
Sep 9, 2006 05:18 PM
