ABS/TRACTION LIGHT ON APPEAR AT 10MPH +
Old Mar 21, 2007 | 12:49 PM
bmwtoaudi's Avatar
Default ABS/TRACTION LIGHT ON APPEAR AT 10MPH +
Good morning everyone!
Well for quite awhile I've had this little issue. Both my ABS and traction control lights stay on after I hit 10mph. - This noted car drives the same with no issues... or so it appears.
Now for the odd. - Today I took it in a parking lot...it hit hard, and im talking hard in a circle while pulling out (It was fun and no one was around) ... lights turned off! ..WHOA!
Anyways I'm more than sure they will kick back in. - I've been told its most likely a speed sensor.
Does anyone know where they are located? - Mind you I have a FWD.
thanks guys!
Old Mar 21, 2007 | 12:55 PM
XCLR8TT's Avatar
Default RE: ABS/TRACTION LIGHT ON APPEAR AT 10MPH +
Get VAG-COM and check the codes next time they come on. The DTC codes will point to which sensor is giving the bad signal... there are wheel sensors on all 4 wheels, and the Longitudinal and Lateral accelerometers under the dash.
Old Mar 21, 2007 | 01:02 PM
bmwtoaudi's Avatar
It started about a week ago, when I was driving in a straight line, I accelerated hard. - Mind you I always do.
Do you think it could be something other than a wheel sensor? - I do not have a Vag. Could autozone run the code?
Old Mar 21, 2007 | 01:10 PM
XCLR8TT's Avatar
Autozone usually won't check the codes unless you have a CEL. The other option is the VAG-tool Locator to find someone near you. But if you are going to do any tuning, I highly recommend that you buy a copy of it.
bentley3282
Oct 26, 2019 07:59 AM
fyreous
Feb 18, 2010 05:11 PM
DARKNIGHTA6
Dec 6, 2008 12:19 AM
Adam in CO
Jul 3, 2007 03:03 PM
Grooby
Mar 24, 2007 01:03 AM
