Aftermarket Radio Whine
Old Mar 15, 2009 | 12:04 PM
dale55's Avatar
Default Aftermarket Radio Whine
Changed out my stock radio for an aftermarket one. Sound is a whole lot better except for alot of engine whine through the speakers. Tried using the ground loop isolators from Radio Shack but they did not help. Any ideas?
dale
Old Mar 15, 2009 | 12:33 PM
hcaudikeed's Avatar
i have the same thing on mine. like a slight beeeeep in the background when the volume is lower?
Old Mar 15, 2009 | 03:09 PM
warranty225cpe's Avatar
Check your plug wires, and alternator connection.
Old Mar 15, 2009 | 05:57 PM
sbreech's Avatar
First things first : Check your grounds. Always ground your audio equipment directly to a chasis ground. Check with a volt/ohm meter. Almost all noise introduced into a car stereo are either from 1.) bad ground or 2.) bad equipment. If you've bought a top shelf stereo (you're putting it in an Audi, why not?), then I'd go with a bad ground.
If you have an EQ and/or crossover and/or amp, it could be bad RCA interconnects. disconnect the RCA's. Turn stereo on. Still have the noise?...
Old Mar 16, 2009 | 05:27 AM
AdamN's Avatar
Member
There is a black wire connected to the back of the factory unit with an eyelet. Cut off the eyelet and tie it in with the ground on the cd player. Good chance that will get rid of it.
Bmart120
B7 Models
Oct 14, 2012 02:35 PM
akobeszko
Mar 13, 2012 03:02 AM
mandito1980
Aug 14, 2010 10:28 PM
BOBB98.5A4QT
Jun 1, 2008 02:10 PM
hypnotiks
Sep 29, 2007 12:55 AM
