airbag light
Old Jan 9, 2008 | 10:06 PM
necra88's Avatar
Default airbag light
i pulled the steering wheel on my audi and replaced the signal stalk with no result's although i hooked everything up correctly my airbag light is on in my dash. How can i reset tha?, or do you tthink its a bad connection?
Old Jan 9, 2008 | 11:04 PM
bmwtoaudi's Avatar
Default RE: airbag light
The dealership has to reset it. - Not sure what you would have done. - I do know when I pulled my seats out to detail my car I found myself forgetting to hook up 1 cable. - Caused the sensor to show up on the dash. - Its like $50 to get it reset. - If you have a vag com you can do it.
I've been reluctant to buy one, but am going to be soon. - I have just about every light on my dash on with the exception of the battery light. - Vag com would cost me as much as it would to reset the lights.
I would l see what the others have to say, but as noted if you do just have to reset it. - Buy a vag com.
Old Jan 12, 2008 | 12:42 PM
achTTung's Avatar
Check your connections, and you can probably try disconnecting the battery for a few minutes to clear it, or take it to autozone or someplace, and see if they can scan and clear your codes with a generic OBDII reader.
Old Jan 12, 2008 | 07:35 PM
bmwtoaudi's Avatar
I think the AIRBAG has to be reset. - I've dropped the battery connection to my car many times and it hasn't gone away. Only thing that happened was I had to reset my radio/clock
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
