alarm keeps going off
Is there a fuse or relay that i can remove so i can still lock the doors with it not going off?
If i don't lock the doors it's fine, but If I lock them it start to beep every 5 min or so.
Seems to happen when it rains, or is very wet outside.
Im guessing you looked in the owners manual already? And if you have then you know were to find the fuse box and the right fuse if there is such a fuse.... I have my manual I can check if you need me too.
Last resort you can just remove the (2) horns on each side of the radiator so at least you can lock the car...
