Washer Fluid Reservoir
I am having an annoying problem with a leak somewhere in my wiper fluid line. Filling the reservoir only lasts a short time (overnight) until the tank is empty, and the warning light comes on again. There are no obvious signs of a leak that I can see. Ideas?
I've removed the fender well to access the tank and traced all the lines and found no leak, so the pump is one of the few options left.
Thanks. It's always something with this car.
I know how you feel.
The best way to test the pump is to fill your tank, turn your headlamps ON and run the washer then just watch. Mine had a nice steady stream of fluid.
Mach Schnell
Mar 11, 2010 09:50 AM
