APR DV and other thoughts
Old May 27, 2007 | 10:04 AM
Siggy's Avatar
Default APR DV and other thoughts
Yo! All -- Bought an 01 225 tt 2 years ago this week. Found this board a year after that and have been slowly sucked in by your collective enthusiasm. Had to see what I was missing so I found an APR dealer and got the chip flashed on thursday. Wow will sum it up. Knowing from this site that a DV upgrade was needed I decided to go with the new one from APR which needs no service . Anyone have any thoughts or experience with this valve? Also will be looking to replace the all too soft intake hose, so how do you get at the bottom connection? Keep in mind I'm no mechanic but I'm willing to give it a try. Thanks and happy holiday to all.
Old May 27, 2007 | 11:50 AM
cincyTT's Avatar
I'm make believe
Default RE: APR DV and other thoughts
The APR dv is a diaphram valve so it will be faster reacting than a piston vavle like a forge 007, and APR has a lifetime warrenty on it also. If yours somehow tears or just doesnt perform like it should, they will replace it. So you cant go wrong.
To get the bottom connection off the TIP, its best to get it from below while the car is on jackstands. This will give you the most room and best view of what your doing.
Old May 27, 2007 | 01:12 PM
AudiOso's Avatar
I bought the APR DV too. I was going to go with a Bailey, but the design of the APR unit made the most sense. I don't care about the adjustability that the Forge has. I just want something that will work properly and flow well.
Old May 27, 2007 | 06:50 PM
Siggy's Avatar
Thankyou for the reply , jackstands are now on the shopping list.
Old May 27, 2007 | 06:56 PM
cincyTT's Avatar
I'm make believe
hopefully along witha nice jack. Mine sucks and it takes longer to get it up in the air. To much effort for me.
Old May 28, 2007 | 12:57 AM
neur0tic's Avatar
With a small (I mean real small) stubby flat tip screwdriver, you can getthe clamp off atthe base of the TIP once all the other connections are off. You've gotta disconnect it all to get the hose off anyhow, but once the rest are off... It's a little easier to get to. I haven't tried from the bottom while up on jackstands... but it is possible from the top. Probably not the easiest way though.
miguelcarlos
Jan 1, 2013 12:06 PM
steeve
Jul 19, 2010 04:07 AM
lwin7
Feb 12, 2010 06:16 PM
awwdii
Mar 3, 2008 06:18 PM
Red_sapphire89
Feb 27, 2008 08:43 PM
