Beginner Mods
im going to be getting a 2001 225 soon. i have been looking for a new car and this is what i have decided on. i didnt realize it needed 91 anyway. My friend john would have fixed me on that anyway. He has a 20th GTI and its chipped and all that nonsense. i have a lot to learn. So chips really are worth it eh?
I wondered that too after reading that. Maybe you shouldn't be modding your car yourself...hmmm. j/k...so you don't own one yet understandable.
Seriously, start with those things if you are looking to get some more powerquickly for cheap. The 225 is rated at 260bhp and 280-290tq after a flash.
yeah thats what john was saying. ill see if it has already been changed or if i need to do that. so the 225 gets ran on 91 constantly? and after i got a chip i would need to reflash the ecu?
The "chip" is the ECU re-flash. Unless you buy an early model TT your new program will be flash loaded onto the ECU via the diagnostic cable port. No removal or soldering of an actual "chip" will occur. You don't have to use 93 octane if it is not available in your location, some chip manufacturers offer a 91 octane tune. You will get better results from a 93 octane tune however. 100 octane race tunes are also available. Are you concerned about paying for 93 octane all the time vs. 91? If so you shouldn't be buying a TT- EVERYTHING for this car is expensive!
websites...
www.ecstuning.com
www.goapr.com
www.awe-tuning.com
www.mjmautohaus.com
www.ttstuff.com
www.thettshop.com
www.pagparts.com <-- good for big turbo/putting together a kit.
www.atpturbo.com
im sure there are more, but good start there
www.ecstuning.com
www.goapr.com
www.awe-tuning.com
www.mjmautohaus.com
www.ttstuff.com
www.thettshop.com
www.atpturbo.com
Offset 32-35ish. Use spacers if desired to adjust stance. 225-45 17 tire on 17 inch wheel=225-40 18 tire on 18 inch wheel- same diameter overall, no speedo adjustment needed. I have seen 15 to 20 inch wheels on a TT, 17's or 18's look and perform the best IMHO. 5x100 is correct bolt pattern although adapters exist to run other 5x112 audi or porshe wheels. Stock wheels are ball seat lugs, aftermarket are usually cone seat- don't mix the two.
