Behind the Dash [Vent style boost gauge finished... with pictures]
Old Apr 30, 2007 | 02:24 AM
  #31
randomloginname's Avatar
Default RE: Behind the Dash
stock, it will hold 5 , and peak to 10ish
Old Apr 30, 2007 | 02:44 AM
  #32
cincyTT's Avatar
I'm make believe
225, you have a leak
180, that is normal, peak is 11psi.
Old Apr 30, 2007 | 01:21 PM
  #33
Do you think it is a boost hose leak, or could that be from a bad dv? Thanks cincy or whomever responds
Old Apr 30, 2007 | 01:23 PM
  #34
cincyTT's Avatar
I'm make believe
dv is always a good place to start. take out the dv and reverse it (inlet in outlet and vise versa). If that works, you have a bad valve. An easier way is to take out the airbox and if you get a honking or early release, you havea bad dv.
Old Apr 30, 2007 | 09:24 PM
  #35
Thanks, Ill try that out and if need be, this would be a good time to upgrade the dv anyways [8D]
Stunter4Hire
Mar 7, 2009 12:50 PM
MLSoccr16
Apr 25, 2007 02:18 PM
boostedB6
Jan 25, 2007 10:25 PM
fher7096
May 13, 2006 06:15 PM
s4me
May 18, 2005 08:39 PM
