boost gauge
Old Dec 1, 2006 | 09:23 PM
XCLR8TT's Avatar
Default RE: boost gauge
You should be able to see around 12-14 psi.
Old Dec 1, 2006 | 09:58 PM
MeanAudiA6's Avatar
i hold at 12 psi but when it was hot out this summer i got around 15psi ans yeah the line from the FPR is under the same boost as the turbo boost pressure.
Old Dec 2, 2006 | 01:02 PM
DenimTT's Avatar
Hope I'm not too late to help. Heres the walkthrough I used.
Boost Gauge Wlakthrough
Looks like it could be an OEM gauge. If memory serves me, I used one of the vacuum/boost lines coming right off the DV. Good luck.
Old Dec 2, 2006 | 05:07 PM
slowtruck's Avatar
i hear somewhat of a ticking coming from the motor when it is running and my check engine light is on. the code was 1128 and it was not my MAF. do you think maybe it is my intake gasket and that is why i can only build about 6psi. i was on the LIE doing about 80 and i put the peddle to the floor and it would not go past 6psi and if i press the peddle the gauge wont move unless i have it to the floor. it also is not smooth at all, it just spikes from 0-6psi and back. there is no in between. here are some pics of the guage. not the best but they should give you an idea. i used the auto-meter pro comp.
http://i85.photobucket.com/albums/k7...8/DSCN0210.jpg
http://i85.photobucket.com/albums/k7...8/DSCN0209.jpg
Old Dec 2, 2006 | 05:25 PM
XCLR8TT's Avatar
ORIGINAL: slowtruck
The ticking you hear is more than likely the injectors, they are very noisy on these engines. The loss of boost could be a number of things. Have you pressure tested the intake system to check for leaks? It could easily be a split boost hose,, loose connection, or any one of a number of other possible leaks.
Old Dec 2, 2006 | 05:43 PM
slowtruck's Avatar
how do i do a pressure check. could seafoam the motor to see where the smoke came from?
Old Dec 2, 2006 | 05:48 PM
XCLR8TT's Avatar
ORIGINAL: slowtruck
No the Seafoam trick won't do it. A lot of times the leaks only show up under pressure. You need one of these from ModShack or you could rig something up like it.
CMoriart
Mar 22, 2011 09:05 PM
slackerscott04
11
Feb 21, 2007 04:46 PM
Soley4pres
Jan 31, 2007 04:08 AM
fenderstrat1184
Dec 21, 2006 02:35 AM
s4me
May 18, 2005 08:39 PM
