Boost Gauge Question???
Old Jul 24, 2007 | 11:43 AM
TurboToughTT's Avatar
Default Boost Gauge Question???
I just got a Garrett Boost Gauge and there are 3 wires coming out of it a Black Orange and Red THere is Instructions, I would like to know where you guys Hooked the wires up on your own TT. Can I run the Red (+) to the battery,?? Please help I really want to install this ASAP
Thanks
Old Jul 24, 2007 | 11:46 AM
cincyTT's Avatar
I'm make believe
Default RE: Boost Gauge Question???
you only need the red and black lines and can trim the orange one off. THere is a place for a nice ground just behind the steering columb and then just tie the red line into a 12v source when the car is on or the lights if you dont need constant lighton the gauge.
also you better post pics so i can see how that gauge looks
Old Jul 24, 2007 | 11:55 AM
Where is there a 12v source on the car i Know I prob sound stupid but electrical stuff is not my fortay.
Old Jul 24, 2007 | 12:02 PM
cincyTT's Avatar
I'm make believe
Do you have a volt meter around anywhere?
Old Jul 24, 2007 | 12:08 PM
Actually i think i do Where could i look for a source?
NOpe nevermind it was for a r/c car
Old Jul 24, 2007 | 12:19 PM
cincyTT's Avatar
I'm make believe
but does it read volts? Makes life easier. I dont remember where mines hooked up and im sure someone will know off their skull where they did theirs.
Old Jul 24, 2007 | 12:33 PM
timbo108's Avatar
Easy pos. connection is a blade tap off a fuse in your fuse box. Ground can be the tinted bolt to the frame under the fuse box cover.
Old Jul 24, 2007 | 09:23 PM
Mobius97's Avatar
When you have the dash apart look at the snap connector that goes to the area where your light and dimmer switch is, there are 2 connections. It is the long connector mounted vertical on the right when looking down from the drivers seat. If you tap into the light blue wire there, the gauge will only light up when the lights are turned on plus you will have dimmer control over the gauge. I believe it is the first lead on the connector....the last lead is a light green colored wire with a few other colors in the middle.
For the ground there is a grounding post beneath the steering column......you can't miss it. It is the one with all the brown wires (ground) soldered to it. Remove the capped nut, wrap your grounding wire around thepost and tighten the nut back down.Don't be alarmed the support likes to bend when removing the nut.
supergoober752
Dec 22, 2009 10:03 AM
TT4fun
Oct 23, 2008 01:45 PM
LuckyCharmsUXZ
Mar 31, 2007 11:34 PM
khj677turbo
Aug 8, 2006 11:23 AM
Vader
Sep 21, 2004 01:18 AM
