boost guage question
Old May 3, 2008 | 03:29 PM
ltsheets's Avatar
Default boost guage question
Just went by MJM Autohaus yesterday and found out that they no longer carry the boost guage that so neatly fits into one of the air conditioning vents. does anyone know where i can still find those? I'd like to get one and get it installed shortly after i get the car chipped which is going to be fairly soon.
Old May 3, 2008 | 03:35 PM
cincyTT's Avatar
I'm make believe
Default RE: boost guage question
all 52mm/ 2 1/16" gauge with the C bracket will fit in the vent. no reason to buy anything special for it
Old May 3, 2008 | 03:36 PM
ltsheets's Avatar
oh nice. thanks for the heads up cincy
Old May 3, 2008 | 08:18 PM
exTTreme's Avatar
I used this one from glowshift I trimmed the mounting holder it came with and used glue to hold a few pieces of it so that air still flows around it. It looks pretty good in the vent and the changing backlight is nice
Old May 3, 2008 | 10:11 PM
twenty8red's Avatar
i bought an auto meter gauge today and made a vent mount out of styrofoam. looks really good and didn't cost a thing. i'll take some pics and post them tomorrow.
Old May 3, 2008 | 11:46 PM
hotgrass's Avatar
here ismy glowshift boost gauge. same as exttreme. but i cutted the ring that came with it to make 4 tabs so that the air could come out.
white
red
the gauge
Old May 4, 2008 | 11:15 AM
exTTreme's Avatar
I actually copied hotgrass because I had purchased the Awe vent guage but it was on backorder and when I saw his pictures it looked just as good only difference is I leave it on pink
Old May 4, 2008 | 11:33 AM
ltsheets's Avatar
nice it looks like that glowshift works out quite nice
Old May 4, 2008 | 12:34 PM
hotgrass's Avatar
i just sanded/dremeled the ring that came with it and cutted it in to 4 small pieces and glued them to the gauge.
Old May 4, 2008 | 12:47 PM
exTTreme's Avatar
That sounds a little bit easier then my method of using the saw blade of a gerber but I also cut the ring into 4 pieces and glued it to the gauge and my easy solution for finding the correct wires was to just poke the stripped end of the wires into the light switch untill everything lit up correctly then splice them
iamderrik
Jun 11, 2010 09:44 PM
outinfront
Dec 9, 2007 01:25 AM
keko2004
Aug 16, 2006 02:56 AM
dafrazi
Sep 7, 2005 10:10 AM
hypnotiks
Apr 27, 2005 03:33 AM
