brake lights stay on even after key is out of ignition!?!??
Old Aug 23, 2007 | 10:12 PM
Blown87camaro's Avatar
Default brake lights stay on even after key is out of ignition!?!??
Just curious if any of you have had this problem........all 3 brake lightsstay on even after car is turned off and key is out of ignition and e brake is taken off..... took out the fuse to save battery....what would cuase this..... bad break sensor??
Old Aug 23, 2007 | 10:17 PM
vince1128's Avatar
Default RE: brake lights stay on even after key is out of ignition!?!??
most likely...
Old Aug 23, 2007 | 11:30 PM
Does the lower dash..... plastic piece that covers pedals come off alone...or do you have to take the whole dash off from fuse box down???? I saw there were 2 screws on the lower portion but when i took them out...the plastic panel covering the pedals didnt budge.
Old Aug 24, 2007 | 12:31 PM
theTTkid's Avatar
have to take the 3 or 4 out of the side too...
Old Aug 24, 2007 | 12:34 PM
techbod's Avatar
failed break peddle switch or it come loose
Old Aug 24, 2007 | 03:44 PM
JaceTun's Avatar
only one thing can explain it, HAUNTED!
Old Aug 24, 2007 | 03:49 PM
theTTkid's Avatar
not those d*** gremlins again...
Old Aug 24, 2007 | 08:53 PM
Yeah took the lower dash apart and pulled the switch out...looks like that may be the issue...i think its broke internally...just plastic.... called everyonee autozone pepboyzadvanced bennit ect no one carries it...online i can get it for $$10.19...ill have to see how much it is from audi tomarrow...since for some odd reason the dealership closes at 8:00 when everyone else closes at 9-10
Old Aug 24, 2007 | 08:55 PM
promethus's Avatar
I vote demonds.
Old Aug 25, 2007 | 06:51 PM
Installed new brake light switch and everything looks good.......had a few problems getting that fkn dash backtogether cuase everythings packed in so tight.
chip
Oct 31, 2017 02:26 AM
CaliforniaGrown
May 27, 2016 06:00 AM
praziquantum
Nov 19, 2011 08:36 PM
03A6owner
Oct 21, 2007 04:03 PM
cbing28
Mar 19, 2006 01:33 PM
