CEL - Code P1296??? Coolant Meter Failure
Old Jan 14, 2008 | 07:05 PM
Oo TT oO's Avatar
Default CEL - Code P1296??? Coolant Meter Failure
My dashpod threw a CEL. Ran a OBDII code reader (from Autozone) and it read the code P1296. Has anyone had this same problem? I just recently had my timing belt changed along with the water pump, etc.
Recently I was stuck in traffic, and the temperature went past the middle point to the next line. Went back to the middle (normal position) when I started to move.
Any advice?
Old Jan 14, 2008 | 07:26 PM
Oo TT oO's Avatar
Default RE: CEL - Code P1296??? Coolant Meter Failure
Also, forgot to mention. This only happened once with the temperature reading more than half. Hasn't happened again, but the CEL light is still on.
Old Jan 14, 2008 | 08:09 PM
moeron7's Avatar
I got the same problem. It may be the thermostat or the you could have a bad coolant temp. sensor. I havent figured mine out yet.
Old Jan 14, 2008 | 08:46 PM
vegastt's Avatar
ORIGINAL: moeron7
Same here [:@]
Russ927
Sep 7, 2012 08:30 PM
Kish
Feb 10, 2012 06:24 PM
h4x0r
Nov 17, 2010 01:13 PM
kevintt
Mar 12, 2008 03:19 PM
dljking
Nov 30, 2007 02:20 PM
