Christmas, Hannukah, Kwanza lists!!!
Ok, Im pretty sure im not the only one who dreams about serious mods and i figure that posting lists of what people want to do to their cars will open up many ideas!!!!
SOOOOOOOooooooooooooooo heres my list..whats yours?
Timing belt shazz(ugh), modshack boost machine, 4bar fpr, 50trim t3/t4 .48a/r vbanded, manifold w/ external gate, Spec stage 3 clutch, oil feed line kit, oil return line kit, T restrictor, oil pan adapter, oil return flange kit, 3' SS DP, 3' Inlet piping set, mounting stud kit, 630cc injectors, inline fuel pump kit, T3 gasket, Pauter 19mm drop in rods, head bolt set, headgasket kit, rod bearings, all software needed, APR FMIC, Milltek dual exhaust, Water/meth, Eibach Springs, Half-Kmac, Short Shift, Swaybars,slotted rotors(not sure which yet) hawk brake pads, blue haldex controller, vag-com/bently manual..... NoS?
Ok yes, itsa lot, and going to be very expensive, but it is everything i want to do / dream about day in and day out... Think i have time on my hands?
So what is everyone else planning on doing?
You asked for it...
DV relocations kit
225 intake manifold
after market exhaust manifold
S4 throttle body
Precision 600 hp intercooler
plenty of aluminum piping
stainless steal piping for downpipe
3-point harness
agent blue haldex controller
dual stage boost controller - turbo xs/smart
scat rods
pins
fasteners
rings
injectors
VF engineering mounts
Spec stage 3 clutch kit
KO4
GT35R
Software for GT35R
EFU4U... if not this exact unit something very similar!
Rims and new tires
Sway bars
Big brake kit
REMUS!!!
Hi-flow racing cats
Wideband O2
Coolant lines
Oil lines
DV relocations kit
225 intake manifold
S4 throttle body
3-point harness
scat rods
pins
fasteners
rings
injectors
KO4
GT35R
Software for GT35R
Rims and new tires
Sway bars
Big brake kit
REMUS!!!
Hi-flow racing cats
Wideband O2
Coolant lines
Oil lines
