Clutch adjustment on 2003TT quattro?
Is the engagement point for the clutch adjustable on the TT? When releasing the clutch, mine engages near the very top which is a little uncomfortable for me as I have long legs. Can it be adjusted to engage/release closer to the floor? If so, any thoughts on how expensive this may be? Thanks.
yes it can, look at the clutch peedle and you will see a bar with locking nuts ( set to your requiremwnts ) but ensure the cluth operates correctly in most cases its a hight sensor/cable type but the newer systems are hydrolic so if it fails then look to air in the system or the clutch is worn
