Compatibility exhaust
Old Apr 1, 2008 | 07:33 PM
Thepianist15's Avatar
Default Compatibility exhaust
Turns out all previous thoughts about my turbo problem were wrong. Wasn't a gasket, its the whole downpipe. I was quoted about 900 dollars to get it fixed, which is too much. I've found 3inch downpipes for much cheaper that I can install myself.
Q: Is a three inch downpipe going to work with the stock exhaust or will stock parts have to be re-ordered?
Old Apr 1, 2008 | 08:37 PM
cmh's Avatar
cmh
Default RE: Compatibility exhaust
An aftermarket downpipe should come with an reducing adapter to fit stock exhaust. Try 42draftdesigns for new downpipe, they are generally considered to be the best quality/value.
Old Apr 1, 2008 | 09:16 PM
Mobius97's Avatar
As cmh posted that's correct..they will come with a reducer. The stock dp is a !biatch! to get out. If you don't drop the sub frame (in which you will need an alignment afterwards) you will need to cut it out with a sawzall. Putting an aftermarket one in, they comes in pieces which makes it easier to get back in. I have the 42DD 3" with both hi-flow cat and testpipe sections. I am currently running the test pipe section now coupled to my Borla cat back. You can install it with hand tools, sweat and blood. I have gotten to be a pro at mine due to the hardware coming apart. I had to keep re-tightening the fastners that came with it because they would rattle loose and then blowing gaskets. I eventually replaced the hardware and everything has stayed tight sense. I did however have the clamp after the testpipe come loose one day but it hasen't given me any issues since.
Old Apr 1, 2008 | 10:42 PM
How much should I expect to pay for that down pipe. That seems to be the best on the market for the 225 TT.
Old Apr 2, 2008 | 08:48 AM
Wintermute's Avatar
$600. But they aren't selling it at the moment. email them & found out yourself. http://www.42draftdesigns.com/
bigred'sB5
Apr 7, 2012 04:43 PM
bigred'sB5
Apr 5, 2012 01:09 PM
zscraig
Jun 13, 2009 06:22 PM
bvnguyen516
Apr 28, 2009 01:28 AM
Selbach
Apr 16, 2007 03:54 AM
