Coolant drain plug?? Pic?
Old Feb 28, 2008 | 09:45 PM
Agnt008's Avatar
Default Coolant drain plug?? Pic?
So cincy said that the drain plug for the coolant is on the driver side front raditor. Does anyone have a picture of it because i can't find it. I found something resembling a possiblity after i removed the plastic engine shield underneath the car and found a circular plastic piece that you can turn left or right and there is a little spiggot right before it. I'm not sure if this is the drain plug because i'm used to actually removing a plug. Can anyone let me know if i'm at least in the right area or if I have to remove anything to get to it??!! Thank you
Old Feb 28, 2008 | 09:56 PM
Red_sapphire89's Avatar
Default RE: Coolant drain plug?? Pic?
i just remove the lower radiator hose and drain it that way on all my cars flush it with a garden hose but thats best done in the summer
Old Feb 28, 2008 | 11:43 PM
achTTung's Avatar
Thats the plug, you turn it, then pull out.
Old Feb 29, 2008 | 02:43 AM
themysteryman83's Avatar
it's a stopper valve. as achttung said you turn 90 degrees to unlockand pull out to drain. should be a diferent color than all the black pipe under there.
cudafish
Aug 15, 2021 04:24 AM
Pbcrazy
Oct 10, 2012 06:35 PM
PacificA4
May 16, 2012 07:53 AM
jmatthias
Oct 9, 2008 11:01 PM
ne2q 73
Jan 2, 2008 06:02 PM
