Correct torque for tightening lug nuts
Old Oct 9, 2007 | 07:07 PM
ouTTie914's Avatar
Default RE: Correct torque for tightening lug nuts
No, you cut me off. Shesh... learn how to post will ya!
ORIGINAL: theTTkid
at me becca?
Old Oct 9, 2007 | 07:14 PM
theTTkid's Avatar
my fault... "ladies first" slipped my mind momentarily
Old Oct 10, 2007 | 07:29 AM
DBK123's Avatar
Actually if you believe in using proper torque to avoid damaging rotors/breaks, the TireRack people suggest using the dry (no lubricant) method. I know it may not feel as good but it will give more reliable torque numbers. I don't know if any of this matters but perhaps just a little lube would at least help prevent lock up the next time the lug nuts are removed.
"Unless specifically stated otherwise, wheel lug torque specifications are for clean and dry threads (no lubricant) that are free of dirt, grit, etc. Applying oil, grease or anti-seize lubricants to the threads will result in inaccurate torque values that over tighten the wheels."
Old Oct 10, 2007 | 07:56 AM
diehlryan's Avatar
The elbow grease was a joke.
Dont worry about hitting a specific torque on the lugs. Just tighted them as tight as you can with the provided tire iron. That way you are sure that you will be able to remove them with the same tire iron.
I have a 1/2in breaker bar that I use. I'm pretty sure I wouldn't be able to use the stock tire iron to remove the lugs. Thats why I keep the breaker bar in the trunk.
erubus
Oct 6, 2012 10:33 AM
Syrinx32123
Aug 14, 2012 09:08 PM
kchao2000
Nov 10, 2009 01:41 AM
Pjbrof
Aug 20, 2009 01:02 AM
Philthykins
Mar 17, 2007 04:19 PM
