creaking and/or knocking sound left front tire
Old Oct 6, 2010 | 09:40 AM
alan93's Avatar
oops spoke too soon, still getting creak from front end, will maybe try replacing strut bushings next time.
Old Oct 6, 2010 | 11:02 AM
warranty225cpe's Avatar
You gotta isolate/identify where it's coming from. Otherwise your gonna be spending money replacing stuff that might not be a problem. I also think it sounds like your CV joint. Mine went out and sounded exactly the same. Just because your boot is still intact doesn't mean it's ok. You need to get it up on a lift and find out where exactly your problem is. Start moving things with a heavy pry bar to look for excessive play or duplicate your noise.
Old Mar 12, 2011 | 05:20 PM
amonty's Avatar
Default same creaking noise front suspension TT quattro 2002
Was plagued by the same noise. The local mechanic changed out the rear bushings on both control arms (which were cracked and worn), and the noise GOT MORE PRONOUNCED!
He then replaced the front sway bar bushings and the noise went away!!!
emericaman1992
Mar 8, 2010 09:41 PM
radioactive
B8 Models
Aug 30, 2009 01:52 PM
JewbinTT
Oct 13, 2006 03:50 AM
sheek
Aug 24, 2006 05:32 PM
Transverse
Dec 17, 2005 09:53 PM
