(DIY?)Testing boost and Vac lines
heres what I made for my pressure test. Its a hand pump for an exercise ball. I attached a thick pen to it, and pushed the pen through the tennis ball. that way there isnt any leakage since the air is delivered on the other side of the ball
now all I need to do is use a $2 pressure guage from the auto parts store
creative. Only issue I see with that is that you won't be able to build much pressure. I built my setup the way I did so that I could pressure test to the same psi that the car runs at. Its rare, but sometimes you can have a boost leak that only opens up after a bunch of boost. Maybe it tests fine at 7psi, but at 15 it leaks. You'll never find a leak like that with a hand pump.
Oh, clamp off the PCV hose with a screwdriver handle. Works great.
these hand pumps can handle more than you would think with the one way valve on this, it should more than meet 20psi. If that doesn't work, I've worked out an idea with Co2 that would only take me a few seconds to add a metered amount of compressed air.
http://www.modshack.info/Pressure.htm
Build yourself one of these.
Cheapest route is a piece of PVC pipe with a cap, and a tire valvestem.
Mine is a PVC cap with a regulator and quick disconnect for an air hose, with a 0-60psi gauge mounted in the side.
Toughest part is producing some sort of lip on the edge of the PVC so the plug doesn't pop out of the turbo inlet under pressure (that can hurt... I know).
