(DIY?)Testing boost and Vac lines
Old Jan 15, 2009 | 08:24 PM
warranty225cpe's Avatar
heres what I made for my pressure test. Its a hand pump for an exercise ball. I attached a thick pen to it, and pushed the pen through the tennis ball. that way there isnt any leakage since the air is delivered on the other side of the ball
now all I need to do is use a $2 pressure guage from the auto parts store
Old Jan 16, 2009 | 08:24 PM
achTTung's Avatar
creative. Only issue I see with that is that you won't be able to build much pressure. I built my setup the way I did so that I could pressure test to the same psi that the car runs at. Its rare, but sometimes you can have a boost leak that only opens up after a bunch of boost. Maybe it tests fine at 7psi, but at 15 it leaks. You'll never find a leak like that with a hand pump.
Oh, clamp off the PCV hose with a screwdriver handle. Works great.
Old Jan 16, 2009 | 08:42 PM
these hand pumps can handle more than you would think with the one way valve on this, it should more than meet 20psi. If that doesn't work, I've worked out an idea with Co2 that would only take me a few seconds to add a metered amount of compressed air.
Old Jan 16, 2009 | 08:59 PM
AdamN's Avatar
Member
http://www.modshack.info/Pressure.htm
Build yourself one of these.
Cheapest route is a piece of PVC pipe with a cap, and a tire valvestem.
Mine is a PVC cap with a regulator and quick disconnect for an air hose, with a 0-60psi gauge mounted in the side.
Toughest part is producing some sort of lip on the edge of the PVC so the plug doesn't pop out of the turbo inlet under pressure (that can hurt... I know).
Pictures don't work for me so this may be of little relevance, but when PVC is heated up with a heat gun it becomes very pliable. you could heat it up and push it down on the bottom of a bowl to curve the bottom out. We used to do this with PVC to make aeroports for sub boxes before I could afford real, well built aeros. if you need the lip on the inside of the pvc maybe you could just flip the bowl over? not sure, like I said I can't see the pictures lol.
Old Jan 16, 2009 | 10:50 PM
Yeah, I do alot of making my own plastic lately. My girlfriends ceramic flat iron has been getting a work out.
Old Jan 19, 2009 | 06:39 PM
achTTung's Avatar
awesome. has she figured out why her hair smells like plastic yet?
Oh, and the PVC reshaping is a good idea... If I build another tester, I'll have to give that a shot.
Old Jan 19, 2009 | 07:01 PM
Nah, my girl Is cool as ****. She would just make me buy a new one if I break it.
vegastt
May 13, 2008 06:49 PM
bemor187
Mar 28, 2008 02:00 PM
HiredGun
Mar 14, 2008 04:33 PM
gotaudi
Jul 19, 2006 01:11 PM
juju4uofa
Jun 8, 2005 08:09 PM
