Downpipe install help
Old Apr 13, 2009 | 12:10 AM
myslow1's Avatar
Originally Posted by 71custom
Finally got it all finished today. Definitely a different sound (but a good one), butt dyno feels the difference. Also, the turbo seems to spool faster, anybody know why? I have the street series with the cat, but I threw a CEL after about 10 minutes of driving. Didn't think I'd need to space the o2 sensors, but I guess so. How much are those bad boys and where is the best place to get them? Thanks.
the turbo spools faster because by freeing it up w/ larger pipe diameter you are increasing flow causing the turbo to spool more freely and faster...
i also have the street series and ALSO have a cel. I have mine because i installed the last piece (part w/ the cat) backwards *embarrassed* lol! I havent had a chance to flip it around yet though. I would say check your code to see if it is the catalytic efficiency below threshold one.... Clear it and if it comes back THEN get the spacer.
the plug defoulers are pretty cheap... prob in the $10 range.
Old Apr 13, 2009 | 02:13 AM
71custom's Avatar
Member
One other thing: I'm noticing that I'm getting a "clunking" sound when I suddenly apply power. I don't get the usual rattle associated with the 42 DD dp, but the clunk comes once torque is applied quickly to the engine. Obviously, some part of the dp is hitting something, but I don't know what. Any idea what might be going on?
Old Apr 13, 2009 | 06:38 PM
myslow1's Avatar
get a dogbone mount.
Old Apr 14, 2009 | 01:12 PM
71custom's Avatar
Member
Are you saying replace the entire dogbone mount or just the stock bushings with stiffer ones?
Old Apr 14, 2009 | 05:45 PM
71custom's Avatar
Member
I assumed you meant the bushings, so I ordered some from ECS tuning (the three piece kit). Any good guides on how to get these things on, or would I be an idiot to mess it up?
Old Apr 14, 2009 | 06:04 PM
AWDrifter's Avatar
Yes just the bushings. And the install is about 100x easier than the down pipe so if you did that your good to go. Take off the under engine cover, 4 bolts holding it on (stretch bolts, should be getting new ones from ecs), unbolt the mount holding the bushings in. Replace the bushing, most people only do the 2 in the back, not the round one. And reassemble.
Old Apr 15, 2009 | 04:49 PM
warranty225cpe's Avatar
^yeah, do the dog bone and only do the 2 bushings not the 3rd(side mount). took me longer to get the car on a lift(cuz its low)than it did to swap out the bushings.
Old Apr 15, 2009 | 06:48 PM
  #18
myslow1's Avatar
sorry yes i meant the dogbone bushings... the install is really easy. I think i had my mount out and reinstalled w/ new bushings in about 15 minutes.
everyone says to get new bolts. I personally didnt, but it is "recommended."
vtraudt
Apr 30, 2014 08:17 AM
mattrazzo
Feb 20, 2011 03:44 PM
gixxerryder
Oct 23, 2008 06:09 PM
quattro411
Oct 28, 2007 07:30 PM
trailboss
Dec 7, 2004 03:54 AM
