DV info
Old Dec 19, 2007 | 12:28 PM
rs2.audi's Avatar
Default DV info
Does any one have pos & con between the" Forge 007 " valve and the" HX Hyperboost "
likes / dislikes ? Forge has a spring kit, I have not seen one the the HX hyperboost
thanks
Old Dec 19, 2007 | 12:37 PM
ouTTie914's Avatar
Default RE: DV info
You won't see a spring kit for the Hyperboost valve, because it's a uses a piston. Stock DV uses a diaphragm.
I don't much about the hyperboost valve, so I can't really say too much about it.
However personally I enjoy the forge 007-A valve, and have not had any problems with it.
Edit: Thanks Josh!
Old Dec 19, 2007 | 01:29 PM
joshuo's Avatar
Default RE: DV info
wait, the stock DV has a diaphragm, right?
Old Dec 19, 2007 | 02:28 PM
ouTTie914's Avatar
Default RE: DV info
Did I say that... woops!
Old Dec 19, 2007 | 04:22 PM
rs2.audi's Avatar
Default RE: DV info
stock have diapham and both the Forge and the HX both have a aluminum piston ( Forge also has a spring kit for the 007
Old Dec 19, 2007 | 04:29 PM
cincyTT's Avatar
I'm make believe
Default RE: DV info
forge comes with a tuning kit and lifetime warrenty, nuff said
Old Dec 19, 2007 | 06:22 PM
.clipse's Avatar
SoCal Crew Member
Default RE: DV info
APR R1 seems to be the other popular choice. diaphragm based, modeled after theBosch 710Nbut more reinforced, i suppose.
the 710N gets alot of praise from tuners, even my friend's evo has one in there right now.
Old Dec 20, 2007 | 02:12 PM
cincyTT's Avatar
I'm make believe
Default RE: DV info
How does your friends evo have a 710? Thats a down grade since the evo's use 34mm inlet/outlets and the 710 is 25mm inlet/outlet.
vair_17
Sep 9, 2008 01:01 PM
jjuzwik
Nov 16, 2007 06:37 PM
bokstas
Feb 25, 2006 12:12 AM
FA123
Feb 22, 2006 06:11 PM
Bizall
Feb 13, 2006 10:05 PM
