Engine Noise
Old May 15, 2008 | 04:10 PM
PaTTy225's Avatar
Default Engine Noise
I have been searching the forums but can't find anything related to my problem.
Recently, when I start up my TT if it has been sitting for a few hours I get this loud and abnoxious ringing noise that sounds like its coming from my engine. It lasts for like 5 minutes and then shuts off.
Anyone know about this?
Old May 15, 2008 | 06:09 PM
ouTTie914's Avatar
Default RE: Engine Noise
What's the outside temperature like when this happens?
Old May 15, 2008 | 07:14 PM
Schroeder's Avatar
I think it is just the raspy stock exhuast when cold starting the car.
Old May 15, 2008 | 07:53 PM
Hitchr10's Avatar
WD-40...fixed
Old May 16, 2008 | 09:00 AM
PaTTy225's Avatar
its been warm actually....i never had the problem when it was cold out......its like a real high pitched squealing noise at startup
Old May 16, 2008 | 12:37 PM
randomloginname's Avatar
SAI?
Old May 16, 2008 | 01:44 PM
PaTTy225's Avatar
I was wondering about that....can it be fixed
Old May 16, 2008 | 01:53 PM
Mine isnt broken, just noisy until the car wramps up/rpms drop to ~900. If y0ou dont like it, turn off your climate control (pull the **** to off) before you turn car off and then dont push it in until car is warmed up. I guess yo ucould/should check to see if you are throwing any codes.
Old May 16, 2008 | 04:18 PM
PaTTy225's Avatar
thanks ill try that
Old May 16, 2008 | 05:25 PM
cincyTT's Avatar
I'm make believe
Its the SAI, it is normal and will be that way until the car is warmed up.
jraffoul
Apr 10, 2017 06:10 AM
kenman
Sep 12, 2012 02:34 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
