Fawkin mechanic
Old Dec 12, 2006 | 01:22 PM
Adam in CO's Avatar
Default Fawkin mechanic
So, I bought the TT as a daily driver to eliminate all the crazy maint. expenses on my Hummer. Doh!
Mechanic wants 1500 bucks for sway bar linkage, belt and tensioner, and hazard relay (damn blinkers). Better than that, the wasted extended warranty wont cover jack.
Any thoughts?
Old Dec 12, 2006 | 01:28 PM
rayveedub's Avatar
Default RE: Fawkin mechanic
DIY. the only hard part is the belt and tensioner. you should do the water pump while your there anyway.
Old Dec 12, 2006 | 01:30 PM
XCLR8TT's Avatar
ORIGINAL: Adam in CO
Any thoughts?
Get an independent shop to do the Timing Belt, you should be able to do that for no more than $800 including parts.
Sway bar is an easy DIY and so is the hazard relay
Old Dec 12, 2006 | 09:29 PM
quaTTro225's Avatar
the "Doh!" says it all
Old Dec 16, 2006 | 12:51 AM
DenimTT's Avatar
Could be worse. You could have bought an A4, then you get all the same problems, but with far less style.
HA
starving030
Feb 28, 2014 08:34 AM
fratedc
Nov 16, 2009 09:10 PM
gzus
Apr 17, 2007 09:16 AM
mattn2005
Sep 15, 2006 07:23 AM
italia
Jun 23, 2005 02:16 AM
