Water Pump Cost
Old Dec 10, 2006 | 02:43 PM
screech's Avatar
Default Water Pump Cost
Hey all,
Does any one know how much does it cost to replace the water pump at the dealership versus getting it done from an outside mechanic. Your input will be appreciated.
Thanks
Old Dec 10, 2006 | 03:07 PM
XCLR8TT's Avatar
Default RE: Water Pump Cost
How many miles on your car? If you are approaching 60,000 miles then you should be considering doing the timing belt, tensioner at the same time. You should be able to find an independent shop to all of it including parts for under $800.
Old Dec 10, 2006 | 03:37 PM
rayveedub's Avatar
i charge 500 hundred for labor so most independents should be there or a 100-200 bucks higher.
Old Dec 16, 2006 | 12:34 AM
DenimTT's Avatar
If you insist on a dealership repair, count on $1000-1200+. You should get the timing belt done regardless, it all has to come off anyways so it wont (shouldnt) increase the labor costs by much.
You dont wanna see the bill after a timing belt failure.
Old Dec 16, 2006 | 02:11 PM
fluidTT's Avatar
Dealership wanted $850.00
I got mine done @ Auto Mechanics for $400.00 (waterpump/tensioners ect)
oraa4
Jun 12, 2015 10:03 AM
MetalMan
Jul 19, 2012 09:15 PM
EdEs
Jul 12, 2010 11:17 AM
Kindbuddy
Nov 21, 2006 09:23 AM
