IT GOT WORSE, passenger door stuck
Old Dec 19, 2007 | 12:25 PM
techbod's Avatar
Default RE: washed my car, passenger door stuck
Adjusting door
Panel gaps
The panel gaps can be checked using setting gauge -3371-.
l
Dimension -A- = 4 mm+1mm
l
Dimension -B- = 4mm +1mm
l
Dimension -C- = 3.5...4.5mm
l
Dimension -D- = 5 mm±1.5mm
l
Dimension -E- = 3.5 mm+1mm
Adjusting door at striker plate
Slacken off bolts -2-.
Move striker plate -1- until door shell is flush with body contour.
Tighten bolts to 20Nm.
Note[/align]
The striker plate must only be adjusted towards the centre of the vehicle and not in height, as otherwise the lock could become damaged.
[IMG]local://upfiles/12092/0477F9CC8ECC496D941E5982644EA652.jpg[/IMG]
[IMG]local://upfiles/12092/534045E675764F8EADD0C2AAA0D1A54D.jpg[/IMG]
Old Dec 19, 2007 | 05:57 PM
jakej's Avatar
Once it melts, your usually good unless it gets wet and frozen again. The already melted water shouldn't refreeze.
Old Dec 20, 2007 | 06:17 PM
laboomba's Avatar
thank you all so much! great info about adjustments!
Barrett
Old Dec 23, 2007 | 11:05 AM
scoTT la rock's Avatar
ORIGINAL: ouTTie914
ORIGINAL: laboomba
the pass door has a bit of play when closed while the driv door has none
As in the pass. door moves up and down?
Could be from the ice you had in there. First thing I'd do is make sure the hinges are clean.
Be prepared for this...
I've found it more frustrating to be at the gas station, and not be able to fuel up!
Even with the ice removed, the bastage of a gas flap likes to freeze shut. A hairdryer or flathead screw driver work well to get it open.
haha same thing happened to me last week with the gas cap, had to get out and scrape it off really well to get it to pop open =)
mypreludeisred
Feb 25, 2010 10:17 AM
gwross
Jan 31, 2009 11:09 PM
blks4
Apr 19, 2007 06:36 AM
98A4V6
Dec 10, 2005 02:23 AM
98A4V6
Dec 10, 2005 02:21 AM
