haldex servicing question
Old Apr 5, 2007 | 09:51 PM
auditt225's Avatar
Default haldex servicing question
So I just ordered the oil, filter, and the wrench. I pretty much know how to change the filter and drain the fluid. My questions is where do I refill the fluid at? The same hole where I drained it from? Im getting mixed ways of doing it. Thanks
Old Apr 5, 2007 | 10:52 PM
Vorais's Avatar
Old Apr 6, 2007 | 08:18 PM
Dana Reed's Avatar
Default RE: haldex servicing question
Believe it or not, drain & using the same hole (another Audi engineering miracle); do some searching and you'll find this answer without too much trouble. I suggest buying a new plug & washer too. Another tip; be SURE the socket is fully seated in the drain plug before removing it; tap it lightly with a hammer to be sure, then add the extension & ratchet. It's easy to misalign the socket in the hole & you can easily strip it because it's such a dinky hex.
Inibalir
Sep 29, 2008 08:24 PM
mikes_tt
Sep 26, 2008 05:19 PM
ttoocool2
Jul 15, 2008 05:10 PM
fireman9585
Feb 2, 2008 12:00 PM
listentodabeat
Sep 26, 2007 12:20 PM
