Heat from under the dash
Old Nov 8, 2008 | 02:11 AM
moeron7's Avatar
Default Heat from under the dash
There is always some sort of heat coming up from the dashboard and my AC is not even on. Is something broken or do i have some setting wrong on something?
Old Nov 8, 2008 | 02:22 AM
vegastt's Avatar
I've had the smae problem, only thing I can think of is that the blower motor flap can be stuck open a bit.
My flap is broken so if I use the heater only the side vents work.
Just my best guess good luck.
Old Nov 8, 2008 | 10:13 AM
keefboz's Avatar
I also have this, don't think its a major deal
Old Nov 8, 2008 | 10:15 AM
randomloginname's Avatar
I think you should be able to tell if it is the flap being stuck open by doing the HVAC diagnostics. If you dont know how, its in the faq, I thinkk its push recirc + up arrow, then use temp **** to cycle through various #'s, each # reports something different. If you just use the first one, you should get a display that reads 0.0. If it gives you anything else, that cooresponds to a certain fault in the hvac system, for which i think the lookup table is also in the faq. So yeah, recirc button+up button, then push recirc button again when display switches, and see if you get 0.0 for an output. To return to normal display, use recirc+up again
Old Nov 8, 2008 | 10:48 AM
achTTung's Avatar
you have a turbo inches from the firewall, and an exhaust that runs right under you. Its just the way it is.
Old Nov 8, 2008 | 08:50 PM
vegastt's Avatar
Off topic but achTTungs sig is the SHIZ!!!
Old Nov 8, 2008 | 09:38 PM
achTTung's Avatar
wish it was original, but i laughed more than usual at the cyanide & happiness strip that ended with that line.
jcmarino
Jan 26, 2012 02:37 PM
Phat_J
Jul 28, 2010 06:45 PM
cu52
Oct 28, 2009 11:50 AM
Excape
Sep 19, 2008 03:07 AM
raffysaudi
Oct 10, 2006 01:11 AM
