help, 225 tt need to add fuel for boost
Old Feb 24, 2008 | 11:40 PM
jetta8vwolfsburg's Avatar
Default help, 225 tt need to add fuel for boost
so just got an audi TT 1.8T and hooked up a boost gauge and my uego wideband. i noticed that at full boost i am running 14.1 lean on my widband and thats because it factory bone stock. so i reset the ecu and started all over and same. so i got unisettings and i need to knwo the rest.
since i need fuel, do i adjust the primary fuel or the increase load fuel? i did the increase load fuel and got to 10% over but nothing changed, so should i also start with the primary or just the primary? and do i need to also increase the injectors duty cycle or leave the same?
any help would be appreciate it.
i have a 2001 1.8T TT quattro 225hp
Old Feb 25, 2008 | 12:44 PM
cincyTT's Avatar
I'm make believe
Default RE: help, 225 tt need to add fuel for boost
The cars all run super lean on stock turbos. Dont ever know why. I would also guess that you are in the 13's in higher rpms also. To increase fuel is to increase duty cycle. Just keep playing with it until you get it where you like
Old Feb 25, 2008 | 11:37 PM
i am actually on the 14s so thats why i am getting a bit scared. so i should adjust lambda or increase primary fuel or increase load?
hermes93
Sep 22, 2014 07:19 PM
Babz
Feb 19, 2009 01:04 AM
Babz
Feb 18, 2009 12:11 AM
Andyid
Feb 8, 2009 11:43 PM
ooantipostoo
Aug 10, 2007 11:13 AM
