Help!!! Convertible top problem.
Old Apr 2, 2013 | 01:42 PM
dark knight's Avatar
Default Help!!! Convertible top problem.
I have the roadster for about a month now, really enjoy the top down from time to time as it was working properly.
Suddenly, last week the top would not go down.
I would unlatch the latch, press the button, nothing happens.
I then manually push it back and down, then the top would go down gradually as I push; near the end the button would work , the motor catches and retract fully. There is no problem closing it, at a push of the button the top will close all the way.
In short, the motor/hydraulics would close but will not open.
I am hoping someone has encounter this problem before and found a solution.
Please advice.
Thanks.
Old Apr 3, 2013 | 07:30 PM
sincityaudi's Avatar
What year
Old Apr 3, 2013 | 10:15 PM
Originally Posted by sincityaudi
What year
04 3.2 V6 Quattro.
Old Apr 4, 2013 | 02:25 PM
It could be the frame potentiometer is geeking out.. Also with the top half open look at the corners and see if there are any strings dangling, if so you need a new headliner because they are built in to the headliner and keep the metal tubular bars in the top taught during operation. If all you strings are good then I know some of the B6/B7 A4 cabriolets had to have an new convertable top module and updated frame sensor to correct the issue you are having.
Old Apr 4, 2013 | 02:53 PM
Thanks, I'll snoop around this weekend.
TT2002_Martin
Sep 12, 2020 01:20 PM
dtb2253x
Nov 6, 2016 07:53 PM
rdscoz
B7 Models
Jul 23, 2009 11:04 PM
lofquist
Mar 25, 2009 03:55 PM
mikeore
Feb 8, 2009 08:41 PM
